xstreamxxx
- Sep 14, 2014
- 2
i need help with this motor fresh rebuild just bought the boat at the end of june the guy i bought it from informed me of the issue of it not going over 2000 rpms but i have done alot of work on outbourds so felt i could fix it was i wrong i am at my wits end at this point what i found after getting the boat is cylinder #4 piston burnt .. drain back gasket broke flywheel magnet loose and soft after rebuilding power head and the other repairs i felt good that i found the problem got it all back together set timing sicked carbs runs great on the muffs so i take it to the river fire it up idle a little low so i turn it up let it warm up put it in gear set idle again and adjust carbs running great so i proceed out on the water get out of the no wake zone and go to open it up and it just bogs down so i back offf on the throttle re check a few things all looks good so i taxi around the water for awile at just over idle for the day get it home check the ignition and compression all seems good but found #2 coil had the ground wire broke in the insulation replaced it back to the river same results tested stator good tested all coils good seemed as if was still droping cylinder #2 so i got a cdi box for it changed that and put the muffs on it now all cylinders are firing good take to the water same result i have checke all wires and conections replaced plugs several times cleaned carbs rebuildt the power head nothing has changed please help
