1995 Force 120hp. Lower unit gaskets?
Dave K.
I'm trying to purchase 3 new gaskets from "IBoats" for the lower unit for when I change out the gear oil. 1995, 120hp. Can someone help with a part number?
I need the serial number which I can't get until I get home and look at the motor, but, the gaskets I'm assuming will be universal for any '95, 120hp lower unit. I could be wrong though, it's happened before.
Ty, Dave
jerryjerry05
The only gaskets are the ones on the water pump assy.
The rest of the seals or O-rings
That what you need?
43033 1 43047 2 817277 Here's the numbers.
The last is the gasket under the pump housing that's included in the pump kit.
Dave K.
Thx Jerry! I want to replace the gaskets (or washers I guess) on the vent, fill and drain screws after I change out the gear oil.
jerryjerry05
I didn't even think about the "gaskets" that seal the drain plugs.
I use Mercury washers on most of my jobs.
The Yamaha ones are a bit smaller.
I buy them a dozen at a time.
Omc uses plastic one time washers. "junk"
