1995 force 40hp serial oe109561
When I got the engine last month it would fire off but never crank. The primer bulb would not get hard so i suspected carb needle not seating or stuck. new fuel hose, rebuilt carb, rebuilt fuel pump, new spark plugs, new non ethanol gas with sea foam in it, new hose, and i bypassed the fuel connector an my tank line is right on the back of the fuel pump. I get a good stiff primer bulb an the engine will crank an run. 1st time for 3 minutes but now will not crank for long sometime very hard to crank. when it cranks i manually go to the throlle arm an try my best to keep it running with a variety of positions... more throttle, less, none, excttt. all this in a effort to try an get a feel for the motor. Can not keep it running. I can walk away for a half a day come back an itll crank but cuts out an hard to crank after that
