Last summer I had an issue with spark in my number three cylinder. A guy who works on boats conducted a pressure test and all of my cylinders are good around 140. This summer I replaced a cdi box, and started getting spark. Had a fuel issue next, so I sprayed some gas into the intake and the motor ran for a minute. I then got worried because no water was coming out of the back of the motor. I was running it in a bucket, with a hose and had plenty of water. I loaded the boat up, went down to the river and found out the battery was dead after failing to get it started after multiple cranks. I then went home and charged the battery. I was going to mess with the carbs today, but I found out that I had no spark in cylinder one again. I checked the wires and figure it wasn't the cdi box. I then changed the power pack. Still no spark. Is my issue the trigger or stator? I have been feeling my way through repairs through research. If it is either, how do I change it, and if I change it, will one work from a 125ph force? This is where I get all my spare parts, could this also be an issue? Thanks for you help in advance.
