So, when I was out last, some of the metal that houses the tilt lock pin broke off probably from pounding around and being 20 years old. I am unable to lock/keep the motor in place and the only thing that holds it in place on the manual tilt and trim is a metal bracket that will come right off under any real pressure. This enables the motor to bounces up and down which could cause all sorts of problems. I've seen this bracket on ebay for $100 but the labor would be too intense for me to handle or afford right now. So, here is what I am thinking:
Either get industrial metal or plastic zip ties or straps to hold it down on the bracket so it can't move. I would just deal with one setting on the tilt (Probably 2nd from highest). This is my plan till winter than if the boat is worth keeping, I will figure a way to do it right. In hindsight this idea seems like it would work. Anyone know if it really would? I would just unstrap or cut zip ties to trailer home then place new ones next time out. Thanks!
