I have figured out that the white wire for my Chrysler outboard is the tach wire. Also, is it correct that this engine is a 12 pole?
I have the same tach referenced in the threads linked below. In these threads it is showing the tach set up for 6 pole for the Yamaha 70hp that I used to have. I am wondering if someone can help me make sense of these threads and tell me how/if I can wire my Chrysler to the Yamaha tach that is installed in my boat. Thanks
http://forums.iboats.com/forum/engi...ards/641912-yamaha-analogue-tachometer-wiring
http://forums.iboats.com/forum/engi.../373939-yamaha-85hp-tach-need-help-for-wiring
