I recently rebuilt a 1988 force 85hp outboard, 30 over, all new pistions and bearings. I set the advance at 28 degrees, with throttles wide open at slow cranking speed. I set the carb tuning screws at 1 1/2 turns out. I did not rebuild the carbs or fuel pump. I put the muffs on it this morning and it fired after just a few seconds and purred like a kitten, I only idled it a few minutes on the muffs then took it too the lake. backed it in the water, fired it up all seemed good so I took it out. only ran it 15 or twenty minutes. it seemed a little boggy and jumpy. when slowly opening the throttle it seems it hesitate for a while then zoom it really takes off, then it sort of bogs again. it definitely has plenty of power when it jumps up. Just wondering if anyone has any trouble shooting advice. also I was getting good water through the exhaust, I did put a new water pump in it. after running it the head was fairly warm but not hot enough to burn or cause pain. One other thing, on the inside of the flywheel the is a sort of magnetic I believe strip that ride on the outside of he stator assembly. this is not fixed on my flywheel and can be jiggled around, is this supposed to be like that. thanks in advance! PS I ran 25 to 1 fuel oil.
