bangshift440rt
- Aug 10, 2014
- 8
1975 CDI Ignition Chysler 55hp. Here's the background: First time boat owner, took it out yesterday, fired right up, ran up and down the river and out into Green Bay a little bit. NO ISSUES at all. Today, the key switch refused to turn the engine over so I assumed dead battery. Battery was not dead. Jumped the ignition solenoid, tried the key again and the key worked to start the engine just like yesterday. So the boat starts up beautifully, I keep it a little bit revved for a minute or so as it's warming up. I go to put it in reverse and it stalls out and shudders. No big deal right? WRONG! Put the boat back into neutral and try to start, it fires on occasion and VIOLENTLY rips the steering wheel back and forth and causes the entire boat to shudder. I assumed fouled plugs so I pulled them, they were wet. I replaced with some brand new spares. tried to start, SAME EXACT THING. It looks like the engine is trying to rotate the wrong direction when it fires! So I get the boat home, put BRAND NEW plug wire in it, took out the brand new but WET spark plugs, cleaned and dried them, replaced everything, squirted some ether, and sure enough, every time it fires the entire boat seems like it's going to twist apart and crack. Could the ignition timing have somehow slipped when I put the boat in reverse? The reason for the ether was because I figured if the gas SOMEHOW got water in it, it would at least start for a minute so I could eliminate the ignition system as the culprit. Thanks for any help!
