Does anybody have an idea on how to remove the lower unit on a 1999 force 120 motor? I removed the 4 nuts including the one on the tail end underneath but still the lower unit is still stuck. Is there something else I need to loosen or remove? I even bought a manual on the motor but it doesn't explain much about removal just those nuts I already took out. I tried pounding it with a rubber mallet but still no luck. Trying to remove it so I can replace the water pump. Any help or answers would be appreciated.
