FisherOwner
- Jul 20, 2014
- 13
I replaced the water pump because the motor ran perfect. Started on first crank and idled like a dream. But no telltale. After installing telltale and new impeller, the motor ran fine but a misalignment in the water tube made the motor get hot. Ran just a couple of minutes and shut it down to avoid overheat.
Redid the water pump job and fixed the cooling issues. (It spits water from the telltale now).
Now, go to start motor (in water tank), and it starts fine and runs for a few seconds and dies. Will not reach idle.
Troubleshooting thus far, bulb and fuel line appears to be fine. Disconnected the outbound line from the fuel pump and turned over motor which caused it to start and die but shot fuel from the fuel line.
Not feeling like motor blown but what else could cause it to run great and now not run at all?
