Had the boat at the lake a few weeks ago and noticed an occasional hesitation at wide open throttle. After going back to idle then neutral it would bog down when I punched it then suddenly accelerate and plane out. It would only do this occasionally, maybe once over 5 or 6 attempts. The hesitation at WOT became more frequent before I headed toward the ramp.
a few months ago I replaced the fuel lines, squeeze ball, in-tank filter and installed a glass filter. Based on the behaviour described above i assumed fuel delivery issue and took the carbs apart, cleaned, installed with new gaskets. When I cranked it up in the driveway it revved up high then quit. I tried to start again with no success, checked the spark and had no spark from #3. noticed rust on that plug, when I pulled the plug wire it came apart, wire connected to spark plug boot was rusted through. Fixed that and tried again, now getting no spark from #1 or #3. These are both fed from the coil pack closest to the bow (#1?), when I plug both of the into the other coil pack I get good spark.
Priced the coil pack here at iboats and other sources (CDI Force Type Ignition 116-5301), range from $280 - $350. I found a used one on eBay for $85.
2 questions;
1. Does the issue sound like replacing the coil pack will resolve the spark issue or should I be looking at other electrical components as well?
2. Is there a better (Cheaper) source for these coil packs? Would you be hesitant about the used one on eBay? (ok, three questions)
Thanks!
Josh
2 questions;
Thanks!
Josh
