Hello,.
I have a chrysler 20HP outboard with control box and cables. I tried to fix the cable on de engine, but only de shiftcable works well, but the gas cable wont work 100%.. If i connect the gas cable on the control box. it only goes from neutral to forward + gas. But when i want to shift to Reverse+gas, The reverse shift wil work but the gas cable wont work in this position.
It now only have neutral, Forward + gas. I tried to play with de clamps in the control box, but still no 100% good working of the cable.
This is the standard cable connection: This way only the shift works, But in neutral the gas is 100%, when i put it in forward + gas. the gas cable is 0% (idle)
This is de mount i have now: Now works neurtral, forward + gas. But NO reverse+gas
Some one who knows about this problem or how i can fix this? Pr can the problem be on the engine? I think the cables only can fit on the standard clamps?
I live in The Netherlands and because of the year of the engine, there are no boatshops who can help me.
Thank you,
Anthony
Thank you,
Anthony
