Force 120 powerhead and flywheel
rzkas
hi and how are you. i bought a powerhead . the seller listed it as 1997 force 120HP . when i received the powerhead it did not come with a flywheel. I am struggling to buy a flywheel and to know the correct flywheel numbers.
here are all the number printed on the powerhead and stickers
4081A46
GA6191200
826196A31
FO-1997
070896
0033562
i bought powerhead to replace my broken 1995 force 120HP . the flywheel from the broken powerhead doesn't fit the 1997 powerhead. the crankshaft is too big for the flywheel to drop in.
can the flywheel be resize?
where can i find and buy a used flywheel ?
thank you
if anyone has a 1996-1999 120 force engine pls send me pictures of your electric set up and mounting location on both side pls.
thank you
