Frank Acampora
- Jan 19, 2007
- 12,004
Look at the tachometer on your car. EVEN a V8 will idle at 600 RPM in gear. Your outboard at 700-750 in forward gear in the water will give a reliable idle with not much chance of stalling. Especially important while docking. It is very frustrating to stall and come in to the dock dead stick. Understand, that the pitch of the prop loads the engine. .The higher the pitch, the higher the RPM in neutral needed to acheive a 700 RPM idle in gear. Thus: RPM in neutral, while always higher than RPM under load, means almost nothing.
