Hi, I am new to the forum and also new to boat engines and repair. I got a boat with a Force 85 hp for almost free and put new spark plugs into it changed the oil and did some general clean up. Took it out for the first time and it ran great the first ten minutes. Then I slowed down and we were going to change drivers, the engine stalled... It started up right away but would never get up to speed or plane out. The engine ran smoothly throughout but just couldn't get up to speed after the first initial run and would periodically stall, then start right up. I have read a number of forum posts online and decided to install a new fuel pump diaphragm (just ordered but not installed). I also checked to see if the gas tank vent was clogged and it isn't (was reading a lot about fuel delivery issues). My neighbor is a mechanically knowledgable and is helping me with the engine. He the said he thinks it's maybe points and condenser or coil pack. I am wondering if anyone on the forum can give me some insight into this or a similar condition before I purchase a bunch of parts. The engine is a Force 85 hp 1987 serial #856X7A Thanks in advance for any suggestions or comments.
