My 85' Force 85hp starts fine,but bogs down and dies when given full throttle. I already replaced plugs and cleaned carbs. This didn't start to happen until I replaced primer bulb with a universal. The flow valve on the tank is wide open and I checked and cleaned fuel filter. Should I replace fuel lines as well? Would a bad coil cause this?
