I took my boat out last weekend. After getting it off the trailer it stalled I restarted it and it stalled again and would not restart. I pulled the motor cover off to check it out. The only problem I found was the one fuse above the switch block blown. I replaced it and the boat started right up. Took the kids tubing and then stopped for dinner. After dinner hopped in the boat and it start right up. Drove the 5 miles to the boat ramp and then it stalled again. I tried to restart but it would not restart. Paddled to the dock pulled the boat out and drove home.
The next day I tried to start the boat on the muffs but it would not start. Started checking the kill switches.(lanyard and the shift switch) all tested good. Kept trying then it started. I was able to start it a couple of time but then it stopped and I was not able to get it started again. It was late so I put my tools away.
Day 3 I tried to start it again but nothing I pulled the plugs and they seemed to have a spark but not strong and the boat would not start. I thought maybe I got water in the fuel so I pulled the bowls off the carbs but they were clean. Nice fresh gas in both bowls.
Day 4 After reading some trouble shooting info on CDI website I thought I would test the electronics. I was think that my trigger may have failed. I took my handy multimeter out to the boat and test the stator out put. The voltage read as AC where 47v on one leg 8v on another leg and 15v on the voltage going to the voltage regulator. I also wanted to test the trigger but was not sure what I would get. While I had my wife turn the boat over I put my leads on the ground and on each one of the four legs of the trigger. I left the spark plugs hooked up as the motor was not starting. When I put the lead on the last trigger wire I got a pop from the motor and it started to run. Yes, it startled me and I jumped the motor died when the leads came off. So I turned on the water and did it again. Yes the motor ran. It ran rough but it ran. So then I tested it on the other trigger wires and got it to start on the last wire as well. But as soon as I take the leads off the motor dies.
Question would this mean my trigger is bad or my switch box bad? Your thoughts, opinions, and question are welcome. I am stumped and need help. The switch box will cost about $250 and the trigger about $80.
Jim
Jim
