Holtzlei
- Jun 29, 2014
- 3
I have a 1988 bayliner with a 125 hp outboard i just had the valve unit on the trim tilt replaced it ran good for one trip around the lake then when i went to pull off the ramp the motor would not trim up it just clicked...it was able to be manually pulled up but after that it would not come down until the hydraulic line was bled we did the relay bypass test it makes a noise like its trying to raise but it does not raise.. Any ideas would be helpful thanks
