I changed the impeller on my 1989 5 hp Force, and when I go to install the lower unit, the lower unit driveshaft will not find the crankshaft hole. This is the second time I've gone through this, and try as I may, the only way to get it to install is to remove the engine and install the engine onto the lower unit drive shaft. Am I missing something? The manual says it goes in without having to remove the engine, but I have not been able to do it that way. Am I missing something?
