Quick history: bought a 96 Quantum 190XFS in the fall of 2012. Took it for a test run before buying it, ran fine. We used it sparingly last year. I noticed last fall that when I tipped the motor up for travel, there was fuel pooled in the top carburetor black cover. I planned on rebuilding the carburetor this spring, figured it was a needle not seating. I did this a couple of weeks ago. Now the outboard starts on the 1st click of the key, idles fine, no apparent issues. I did not touch the lower carburetor.
Problem: Took it to the lake this morning for a run with the wife. Motor ran fine, idled nice, topped out around 38 mph at wide open throttle (WOT). Loaded up to go home and pulled the cover on the motor. Fuel had apparently been blowing back through both carburetors. Both black carburetor covers had fuel in them and it was apparent fuel was spread around the front of the motor. The only thing I can say that I noticed was that when going to WOT, the rpms jumped easily from 4800 to around 5300 like the prop was slipping, but very little increase in speed.
Diagnosis: Got it home, did a compression test on the 4 cylinders: #1 130 psi, #2 140 psi, #3 140 psi, #4 145 psi. I also hooked up muffs to the bottom end and ran it in the drive way. I ran it in the fast idle position to see if I could induce any fuel to come out of carburetors. I even goosed it at the throttle linkage as much as I dared in the driveway, don't need cops showing up for excessive noise, but no fuel coming out at all.
Question: If a reed plate assembly has a reed or reeds bent a little, could this cause the fuel spraying out of the carbs at WOT?
Any help would be most appreciated.
Darren Needham
Andover, Ks.
Darren Needham
Andover, Ks.
