I have a 1990 90-hp Force that ran fine in both idle and wide open, but the cold starts became very difficult to the point of needing starting fluid. Last summer the boat would start with a flick of the key, but I had a bad fuel episode towards the end of the season. So I rebuilt my carbs last week by spraying them down with carb cleaner, then used compressed air to clean them out, and lastly installed new gaskets. I verified the floats were at the proper height and I had installed new jet needles last year. When I tested the boat the engine started and idled fine but bogged down when trying to get up on plane. So I disassembled/cleaned/reassembled them again thinking I had either assembled them incorrectly or had some debris that I missed. I retested the boat out last night and got the same results (couldn't get up on plane) so I am at a loss of what the problem is. I did an on-the-water link n synch by adjusting the air mixture screws and the throttle cam/tower/roller, but none of these helped (the throttle plates were horizontal at wide open). In addition, I primed the bulb (it was solid) while trying to get up on plane but it didn't help. To review, this what I have done so far:
1) Compression check last fall (passed)
2) New spark plugs
3) Carb rebuild (cleaned/new gaskets recently & new needles in 2013)
4) link n synch. Adjusted the throttle cam, tower, and roller as well as air mixture & idle screws.
5) New fuel lines from gas tank to carbs (last fall/this spring)
6) Fresh fuel (running off portable tank)
7) New fuel filters.
So I have no idea what could be causing the bogging especially since I have replaced/eliminated a number of variables. So I need some ideas of what to check or do next! I plan to recheck compression this weekend (even though i did it last fall).
2) New spark plugs
