OldBoat2022
- Sep 22, 2012
- 14
Just changed the lower unit oil in my 1975 45hp outboard Chrysler. I made a stupid mistake and removed the Gear Shift Arm Pin instead of the drain screw. Looking at the parts diagram, I believe that is the right terminology for the part... When I noticed what I had done, I put it right back in and tightened it back down. I had to kinda wiggle it back into place to get it to go in.
So with that being said my concern is, did or could I have messed something up. Everything seems to be working right when I check it by hand. I am new to this and thought it might be worth while to ask someone that knows these motors before I take it out, potentially costing myself more money.
Another question, most outboards I have seen will hand turn the opposite direction of the gear its in. On this Chrysler I notice in gear I cannot turn it either way without turning over the motor. Is that normal? In neutral it will turn both directions.
Thanks in advance for any replies.
