gregmsr
- Sep 20, 2006
- 391
Got the boat out after setting all winter (some days below zero this winter).
New fuel filter, fuel pump diaphragm, tested overheat buzzer, just a few maintenance items.
Dropped it in the tank, fired right up.......all is well, pumping water out the tell tale, sounds good!
Then, after about 5 min, the buzzer sounded....first time i've ever had it sound.
Shut it off, grabbed the heat gun and read 180 degrees on the head.
Hmmmm......
Got out the air hose, shot a few blasts up thru the tale tell, bubbles coming up out the tank.
Fired it back up, no buzzer after that... pumping water very well, all is good (I guess).
Now, i assume a critter had built a nest somewhere, some sort of blockage i guess.
Using the heat gun, these are the temps I read shooting the block, then the cylinder head at the level of the spark plug holes while running:
Block- 120-130
Head from top top bottom- 128, 140, 153, 157.
I found it interesting the temperature got warmer the further down you go.
Water falling down thru the block heated up as it fell down, I assume.
Any comments on these temperatures? (now to get off work long enough to put it in the water)
Anyway, some interesting stuff...to
Hmmmm......
Block- 120-130
