I?m fixing 1989 Force 5 hp as a favor for my neighbor, it was sitting for 2 years under an open carport. I got it going and it has good compression (115 psi cold), but the shifter handle is hard as a rock to move, the prop has one blade missing, it has no engine cover cowling, and the bottom cowling is damaged. I look online and the impeller is like $68 minimum new, and the prop is used like $60 minimum. I?m thinking this might not be worth fixing?
Anyhow, I?m wondering how I can know if the water pump is working, I don?t see water coming out of the little exhaust holes that point down on the back of the middle of the drive shaft housing. I look on YouTube videos and can?t see water coming out of those either. How does one know the impeller is bad if there?s no pee hole?
