I just purchased a 87 Bayliner w/ 125 HP Force I set up a large water trough to test run the motor. Runs good but a small amount of oil is on the water after after it is done running. Could that be caused by excess oil in the gas. Or where else could it come from. I did not run it in gear, just at idle. It had a new impler put in the water pump last year and it pumps water real good.
