madhoosier853
- Apr 15, 2014
- 8
I have a Chrysler 9.9 model 92h00, it ran great last fall for duck season. So I took it out this spring and was trying to start it to sell it and boy did I look stupid to a potential buyer because now it will not start for anything. I've taken the carb off and cleaned it all out, it had fresh clean gas in the bowl from priming. Checked for spark with the plugs out and it has spark, although they were soaked like it was flooded, which it seemed like that happened everytime even when I didn't use the choke. I tried using starting fluid just to get it to turn over and nothing(and yes I did check to make sure it's in neutral, usless there's a sensor or something broke that I'm missing). Also there's a small hole just above the cavitation plate that sprays out gas and oil, never did that before, but my friend says that's an "overflow" outlet. Any suggestions?
