Hello!
I bought a 93 bayliner 1800 with a 125 force(says by mercury) from the orig.owners.the engine ser.is OE016608.Engine starts and runs great,so far on a hose.I was concerned about the age of the impeller and bought a sierra 18-3251.I dropped the lower unit,remover the pump housing,removed the impeller(which was actually ok)installed the new impeller and reassembled it.I should mention this has the "D"type lower unit.I hooked up the hose,started it up and the pump was working fine,warm water from the upper holes,and cool water from the exhaust.What bothers me,now I have water leaking between the lower unit and mid section,as well as around the bolts.There also seems to be a weep hole by one of the bolts and a streem of water is coming from there.I have a seloc manuel,and must of missed something.Any ideas?
