I am replacing the water pump impeller on my 1989 85hp Force. Since the lower unit was off I wanted to see how much water got to the impeller with just the muffs on. I have rectangular-shaped muffs with water supply to each side. With water faucet on full (approx 80 psi) I get no water to the water pump. Is this normal? Does the impeller have to be turning to get water up that high? The water lines are open in the lower unit are open - water drains out the bottom when I pour it in from the top.
