We were out fishing yesterday, motor was running fine. We were using the tilt frequently to lift the motor and drift over kelp to pothole-fish for bass. Lowering the motor, got it 3/4 of the way down and then no power to the tilt or the ignition. We were able to manually start the motor with the prop barely in the water, so we were able to get her home. I don't see any blown fuses. The only one I can find is a yellow ATO inside the engine. I replaced it even though it looked fine. Thoughts? all the other instruments in the console have power.
