HotTommy
- Mar 15, 2013
- 1,025
I'm buttoning up my 1993 Force 150 outboard after replacing one piston. I just installed the head and a new head gasket. My factory service manual says the bolts should be tightened in the order specified to 75 in-lb, then 125 in-lb, then 175 in-lb, and finally 225 in-lb. My torque wrench and I are used to working in ft-lbs, so I converted the specs and discovered the maximum torque level is barely 19 ft-lbs. That's little more than finger tight in my world. I don't doubt the FSM, but I'd feel reassured if some of you with much more experience than me told me this is indeed correct. That barely seems enough bolt stretch / clamping force to keep them from vibrating loose. There was also no mention of either anti-seize or Loctite.
