bnetzky
- Mar 26, 2014
- 9
I am new to boating and outboard so sorry for the rookie question.
I recently bought a boat with a 1976 75hp outboard. The previous owner agreed to change the fuel lines and clean the carbs before I took although it was able to fire up ok.
So, I had some time and I opened the cover to take a look at the motor and found the fuel line leading form the tank was not connected.
Is the fix as simple as getting a hose clamp and attaching the hose from the fuel tank to where the cut hose is? (I ordered a manual but it hasn't come yet).
Also, I found that he did not put the carb cover back on...
