joshackley
- Apr 10, 2013
- 38
I'm going to look at a new motor for my boat Saturday. It doesn't have controls, but otherwise should be a complete motor. I want to be able to start it so that I can verify it works. I know that I'll at least need to take a battery, fuel tank, hose, primer bulb, and probably a remote start switch?
I've heard that without the control harness being connected, you can press the choke button on the choke solenoid, and then use a remote starter switch to start it? And then to kill it you can press that choke button again? Is that all that needs to be done in order to get it started and kill it?
