adamjoelmusic
- Mar 22, 2014
- 22
hey there guys! first off... thanks for all the help so far on this forum! you guys have been a real super help - i am fairly mechanical and can do just about anything i am told mechanically but this outboard is new for me and I'm slightly lost on the old stuff -
that said.... I'm wondering about water cooling system on this one ... when i sit just idling, i see NO water coming out of anywhere... when i manually rev up the RPM's i get a little spurt of water out of the 2 small holes in the back of the motor just below the cowling cover (exhaust?)
i noticed after sitting for around 10 minutes idling last night that the motor was unusually hot.... after removing the lower unit and inspecting the impeller, everything "appears" to be working properly ...
thoughts...
thanks
thoughts...
thanks
