dancewithme951
- Jan 27, 2014
- 75
Just acquired a 1989 Bayliner with 125HP Force. This boat had been sitting for at leat 2 years so I expected the worst (but got a sweet deal so why not?!). A number of relatively minor issues need to be addressed but first attempt at starting and the motor would barely crank with fresh battery...starter checked out fine I removed all 4 plugs and poured about 1/4 cup of Seafoam into all 4 cylinders and let that sit overnight. The next day, with all plugs reinstalled, water hooked to lower unit with ear muffs, she cranked right up and easily started. I was amazed! It ran surprisingly well but with occasional miss. Once sufficiently warmed I did a compression test, screw in teter and with throttle wide open. All cylinders tested out at 140 PSI but one - not sure the # but third one down from the top - which was 80 PSI...YIKES! My question for any takers: is there a possible cylinder specific quick fix for that one cylinder? Cannot afford to have engine rebuilt. Decarbonization perhaps? Any advice is appreciated.
