catarinacci
- Mar 8, 2014
- 2
I have a 1995 force 40hp with a bad cylinder. Would like to change the power head with a 1992-94 power head. I have been told that the adapter plates are different. I have both adapter/spacer plates for both power heads. Is it possible to make this change and if possible what adapter/spacer plate would be used? Any info will be appreciated along with any other problems I may encounter with this swap. Thanks
