Wormy_1709
- Oct 26, 2012
- 8
I have a 15hp Chrysler Outboard. I want to change the oil in the lower unit, but i cant find an oil pump fitting that will fit my engine. I was wondering if you HAVE to use the pump or can you just drain it, put the bottom screw in and just fill it from the top screw hole till it starts pouring out? Basically the same concept as changing the fluid in a transmittion. Any help would be appreciated. Thanks.
