I've got my boat finally running soundly (for now) and have it pimped out with accessories. There is already a dual battery switch installed. I have read different opinions on dual batteries and am looking for some advice. The seloc manual for my 1979 chrysler 700 skier 70 hp says that the engine should be able to sufficiently charge the battery after starting and using electronics on board. However, electronics have come a long way since 1979! I have an aerator, bilge pump, running lights, horn, stereo, chart plotter, and fishfinder. My concern is that if I use all of these on the same battery, with the engine off (listening to the radio and using the live well while fishing) the battery will drain and I will be dead in the water. Any opinions on this before I do a "trial by error?"
If I do install the second battery, I would have one as just a starting battery and one to run the electronics. Doing some research, I have seen that the engine may or may not be able to charge both batteries. I'm thinking it probably will not. Therefore, what would I put the battery switch to? Keep it on the starting battery and just drain the battery on the electronics down until I get it home and on the charger? I know I could start it and switch the battery switch over to the electronics battery to charge, but I think I also read that this isn't recommended.
Thanks in advance
Thanks in advance
