MickLovin
Master Chief Petty Officer
- Feb 18, 2013
- 822
Ok, after running this motor for a while I pulled the lower unit oil screws out to check the oil and found it already black and with water in it, after changing it when i got the motor. Looks like I need new seals, so may I ask is it the seal in the water pump housing and the one below the housing I need to worry about or is there more, as I said the oil was black so I am thinking it is coming from those two seals not the prop seal I hope. Have 2 seals on order anyway so I will let you know how I go with this problem. Also at the moment I don't have a manual for this motor, and I am unsure about timing and carb settings etc. Can someone help me out with some basic tune up guide for this or am I better off waiting for a manual.
