Motor runs good, no water in cylinders that I can see. Not overheating. Just rust around some bolts on exhaust plate, and a small trickle of water running down. My issue is I want to take the plate off to inspect, and I've tried working one of the bolts out, keeping in mind that it may break. Well, the second one did, and I stopped there, and lightly checked others, and I feel several more may break also. Having never worked on this kind of engine, and from the pics I can find on the net, show water passages. Anyone have a good method of heat? PB Blaster? tapping on bolt? experience with this issue? Thanks. Ed
