Re: Kill switch on Chrysler 100HP
Thanks Nordin, it is a 1979 model with I believe to be the Motorola system which would use a normally closed switch in series with the blue wire ignition switch or the red supplying the ignition switch, the blue supplies the electronic box, I was unsure if Chrysler actually did one, I am an electrician by trade and have no problem with the wiring. Would you know also if the hole in my surface mounted remote is for the ignition switch or a start light, I believe they also made a light which indicating start, they have one on Ebay but want $35US plus $22 US delivery, I can buy an industrial indicating light for $10 at the most which would be stainless surround.
