Re: 12.9HP chrysler model 122HC 1972 or 1
thanks mate
its my new spare I got on ebay for $23.30 ROFL, it runs but didn't pump water so I pulled impeller apart and checked, it looked ok could use a new one, I emeried inside the housing as it was getting a bit pitted, lubed and put it back together, the bloke who had it before had put one gear housing bolt in the water pump housing so I fixed that and am hoping it will pump water, it needs a new seal on the housing and under it, as it had clear water in the lower unit, also a couple of the small holes in the gear housing where blocked so I cleared them as well. I have changed the gear oil as it was black and thick. Don't know much about these motors, I believe the recoil on the pull cord isn't workinh either.
