hmantractors
- Jan 13, 2014
- 8
Hi, all. Removed a bad 1992 force 70 and replaced with a very good 1996 force 75 powerhead. I used all the electrics from the 70 and installed on the 75. My first question is, should this work? My problem is it will not start. It will backfire. So it is out of time. I can disconnect the trigger and in the full range of motion it will only backfire. With a timing lite installed it seems like it is way out of time. Anyone have any experience with this swap? I do not know if the trigger is different between the two other than maybe a molded plug on the end. Would like to solve this on my own before I have to resort to repair shop. Thanks for any possible help. I do not have any electrics for a force 75 to try to resolve problem. Would be willing to buy needed parts if somebody has them.:help:
