hi there,
I have a chrysler 105hp outboard and it wont pump water. I have had the leg off several times, it has a new impeller and will flow if a hose is connected to the water pick up with leg leg off. I have replaced the thermostate with a restricter plate and checked the releif valve. I removed the prop to see what happened when reving the motor breifly, the rear of the leg bubbled like the pump was cavitating.
Please help, I love this old girl but am very much stumped.
