I have 2 gray wires coming from the stator i bought this motor missing the rectifier for battery chargeing , i know the stator producrs AC volts i know how to connect the rectifier up just want to double check , does it matter on wich terminal the gray wires go on i also know one terminal out of the 3 goes to battery + that leaves me with 2 terminals for 2 gray wires , as AC volts is alternating curent how to tell wich gray wire goes on wich terminal . iam aware that the rectifier has a blocking diode biult into it .thanks :joyous:
