3rdMarDiv
- May 27, 2013
- 49
Just pulled the flywheel and found laminated coil looking bad. (see pics)...:blue:
I tested the ignition coils with and ohm meter and got 730 on both coils. Is this OK...?
The laminated coil on one side looks fine, but this one looks pretty rough. Would you replace this or is it still functional?
Lastly, do you know what voltage I should be seeing being produced or delivered to the spark plug through the spark plug wire...?
Thank you for all your help
