Big Fish Billy
- Dec 31, 2009
- 301
I have had my lower end down a couple times to work on my water pump, starting in neutral, each time I put it back, the boat was in gear when I started it. I popped the shift linkage off and manually clicked it into neutral and adjusted the linkage to match. Same thing happened today, seems like it has to go back to where it was before I did it the first time. Is this normal or what am I doing wrong? I'm sure the shift linkage you have to undo to drop the lower end is exactly in the same position each time.
