Re: 90 hp force
The old rule of thumb is to divide the horsepower by 10 and that is what you would get running at wide open throttle. That would relate to 9 gph for that engine. That is a rough estimate and can be improved by finding the sweet spot on your particular boat. Usually about a hundred rpm more or less over what it takes to keep it on plane.
