homelite
- Aug 13, 2002
- 156
OK, so I'm replacing an impeller, a simple job, right? I can't get the driveshaft back in the lower unit. Does the pinion fall out of place? I shake it around and something is rattling..... No gear oil is in there.
Do I just play around until I get the pinion in the correct spot to get the d/s splines to line up? Is that the problem? I never had something so stupid happen and I don't want to tear apart the gear housing as it is practally brand new and I don't want to cause any other issues because it runs fine.
Thanks,
Thanks,
