gwgautney
- Aug 28, 2013
- 283
I am trying to figure out this motor. I am getting fuel to everything, appears to have spark. Did a compression check yesterday #1 was 110 #2 was around 90 and #3 was around 75 or 80. When I put water to it it still would not crank then it acted like it was hard to turn over after that. What are the signs of head gasket failure and how would I check. Also would bad head gasket be cause of it not cranking. Thanks for any help
