Re: 1975 75hp Chrysler Carburetor question
Very good. Yea, any sensible person would not mix carbs. But I did it while troubleshooting a plug fouling issue at the same time that I Frankenstiened a Mopar ignition box and a very energetic MSD Blaster2 coil ignition system onto this thing, the latter of which was the best thing I ever did to it, along with running L86C plugs. I did some strange things with the electronic distributor to time it in correctly since the firing logic of the Mopar box is opposite the CDI unit. The optical pre-amp interrupter triggers the Mopar box nicely. I"m not going to post how I made it work due to the probability that someone will try it and blame me for their burned up pistons. I will just say that the 3 cylinder electronic distributor is perfectly set up for opposite logic triggering of the Mopar unit with some minor hacking and major timing corrections.
I pull my cylinder head once each mid season to inspect the piston crowns and they still look like new but I keep my revs under 4000. I occasionally bore scope the cylinders also but I like pulling the head better.
The circuit was pulled from a Kawasaki 750 3 cylinder motorcycle engine modification I found on the internet where the guy wired in a Mopar box triggered by the Kawasaki's interrupter. The distributor mod was my creation. Mopar boxes are cheap, you can get them for under 20 bucks and they are good coil firing units. Also, I'm able to run any automotive tach with this setup on the 6 cylinder position since a 6 cylinder 4 stroke and a 3 cylinder 2 stroke have the same number of firing events per one revolution of the crankshaft.
Corrosion is not too bad for 6 years of salt water operating. That's another great thing about these Chryslers. With religious fresh water flushing immediately after boat retrieval, they take salt water operation very well.
The engine in operation
These experiments like this come from 40 years as a professional wrench, being a marine diesel tech working for Cummins, and I can be a bit outside the box doing engine work (I can burn up pistons with the best of 'em! LOL). I can monitor things closely to know when things start going wrong, and this thing has been absolutely amazing for reliability and total trustworthiness in the Pacific Northwest ocean environment. It's a 1975 75 horse Chrysler just like the OP has. After 550 ocean hours I think I'm sticking with this engine model until I'm too old to do this anymore. I was going to repower with a 4 stroke but the more I use this engine and the low cost of operating it, it just doesn't make sense to spend thousands on a repower.
Anyway, I never did put the 75 carb back on the #2 hole. This thing has been flawlessy reliable. By the way, the plug fouling issue happened when I was trying out Pennzoil 2 stroke oil at the same time I modified the ignition system, and put that carb on during troubleshooting. The Pennzoil just didn't burn right, it just gummed up the plugs. I went back to Valvoline which works perfectly and so does the johnson evinrude stuff. The L86C plugs are really a nice match to the MSD coil but man they put out some hellacious ignition noise (non resistor plugs). Cuts my VHF receive range down a bit but I really don't care. I get 3 seasons out of a set of plugs with this combo without fouling once, about 150 hours or more. So the moral of the story is that as insane as the above configuration is, the results over 6 ocean fishing seasons are good with no failures or hardware deterioration of any sort over a 550 hour span. If I ran at WOT which I never do, the story might be different. Ocean running at high speeds often results in going airborne and I don't like that.
I like your posts Frank and they are a totally valuable resource.
Anyway bsas2, Frank is the supreme expert on these engines and you can't go wrong following his recommendations. Don't do anything I do because I am just too independently experimental, and experiments like mine can lead to disaster. I've been following Frank's posts for years and they have some really great stuff in them.
Robert Reed
